Okay, so after starting to build my HTPC, I want to upgrade my existing dekstop into a watercooled PC for it to be quieter and cooler.
Current desktop build:
CPU: i5-3570k
Motherboard: ASUS Z77 Sabertooth
RAM: 16 GB G. Skill Ripjaw X (2x8GB) 1600
Graphics card: GTX 680 SC+ (moving to a GTX 780 and putting 680 in HTPC)
PSU: SeaSonic 650W modular
Case: Fractal Design R4 windowless
I don't need to look at the watercooling loop right now. I might get a windowed panel from Fractal in the future since they're kinda cheap.
I have no idea which parts are the best for watercooling. I wouldn't mind getting a T-Virus reservoir for when I get a Windowed panel.
Build colors are going to be Black and Blue. I might do custom sleeving like Linus did.
Also, the important question, is a water cooling case generally move able? Because I take my desktop home with me on breaks from college, such as Winter, Springbreak, and summer. I have to lay down the case on its side most of the time. Would that be a problem?
Budget is between $1000-1500. Can go over if necessary.
Desktop: Intel i5-3570K (stock) | Asus Sabertooth Z77 | G.Skill RipJaw 16GB 1600MHz | Samsung 840 120GB | EVGA GTX 680 SC+ 2GB | Fractal Design R4 | Windows 8 Pro (soon to have dual boot Mac OS X)
Retina Macbook Pro : Intel i7-3840QM | 16GB 1600 MHz | 256GB SSD | Nvidia GT 650M 1GB | Mac OS X 10.8.5
https://linustechtips.com/topic/39110-first-watercooling-build/
Moving might pose a bit of a problem with a w/c loop but as far as the components go, take a look at the watercooling 101 sticky in the watercooling part of the forum
[spoiler=Current Rig:]i5-4670K @ 4.4 Ghz on 1.3v | MSI Z87I | GTX 780 @ 1150 Mhz | 2x8GB ADATA XPG | Samsung 840 250GB SSD | CM V700 PSU | Custom Watercooled in a Caselabs S3
[spoiler=Peripherals:]Mad Catz R.A.T. 7 | Corsair K70 | Sennheiser Urbanite headphones | Corsair Vengeance MM200 | Asus PB278Q + Samsung 22"
https://linustechtips.com/topic/39110-first-watercooling-build/#findComment-503581
