I am new to computer building and i am upgrading my computer. I have a really old Compaq Presario PC and inside is a Geoforce GT 520. I am getting a
Corsair CX Series CX600 600W ATX 12V 80 Plus Bronze Power Supply,  GIGABYTE F2A88XM-D3H mATX FM2+ A88X DDR3 2PCI-E16 PCI-E1 PCI CrossFire SATA3 HDMI USB3 Motherboard,
AMD Athlon X4 860K Black Edition 4.0/3.7GHZ 4MB 95W FM2+ Processor,
Corsair CMV4GX3M1A1333C9 4GB 1X4GB DDR3-1333 CL9 Memory Module.
I do know AMD processors and Nvidia GPU arent the best combos to go with. But im on a budget. I just want to make sure everything goes together and everything is going to work once I put it in the computer
https://linustechtips.com/topic/390349-i-need-help-asap/
And your question is?
Molex to SATA, lose all your data
https://linustechtips.com/topic/390349-i-need-help-asap/#findComment-5269517
How much is your budget? Also where is your location?
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/390349-i-need-help-asap/#findComment-5269532
This does not matter at all.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/390349-i-need-help-asap/#findComment-5269534
Your PC gives a shit about what brands you combine. That's just an internet mystery. What is not a mystery is e g: High-End AMD CPUs are enfirior to High-End Intel CPUs but this is not of importance in your case.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/390349-i-need-help-asap/#findComment-5269590
I would upgrade that GPU quite quickly but everything will fit. Also: It does NOT matter wether you are using different gpu/cpu brands a single bit! Your cpu will not give a damn about what brand gpu you are using. Thats one of the worst myths i've heard about PCs and its one that has to get out of peoples brains.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/390349-i-need-help-asap/#findComment-5272279
