I am trying to code a front-end for a SQL database in Visual Basic. I am having trouble writing a query that will take what is entered in a text box, and use it to search the database and return a list of all relevant items.
Dim entry As String = txtbxMANU.TextNewreport("SELECT [Manufacturer] FROM [Instruments table] WHERE [Manufacturer] LIKE XXXXXX ")
I wish to query the database for a manufacturer and produce a list of all items made by them.
Any ideas on how I can do this? Is it simply a lack of knowledge of syntax or is there more to it?
Cheers guys
Mike
https://linustechtips.com/topic/39034-sql-text-form-help/
Never mind guys, figured it out, after 6 hours I figured it out 15 minutes after asking for help hahaha
If anyone is interested
Dim entry As String = "'%" & txtbxMANU.Text & "%'"Newreport("SELECT * FROM [Instruments table] WHERE [Manufactuer] LIKE " & entry)
https://linustechtips.com/topic/39034-sql-text-form-help/#findComment-502626
Hey just wanted to say, remember if this is to be released to anyone to watch out for exploit code :p
My sql is a bit rusty, but what if someone entered in the following:
(delete [instruments table])
I don't know about VB, but usually there is a sql function that lets you parse user input for exploits....
0b10111010 10101101 11110000 00001101
https://linustechtips.com/topic/39034-sql-text-form-help/#findComment-502658
Hey just wanted to say, remember if this is to be released to anyone to watch out for exploit code :P
Your absolutely right, it's open to SQL injection attacks, Ideally using parameter's rather than concatenated text to build the SQL should sort the exploit, however failing that a simple way to mitigate most of the problems would be to change the first line to the following
Dim entry As String = "'%" & txtbxMANU.Text.Replace("'", "''") & "%'"
Current Rig (Ongoing Build)
Spec:- 4770K | GTX 780 | 32Gb 2133Mhz Vengeance Pro | CaseLabs TH10 | 2 x 840 Pro RAID 0 | 3 x 3Tb WD Red RAID 5 | Maximus VI Formula | LSI MegaRAID 9271
Cooling (Ongoing Build) :- EK CSQ Clean | EK FC Titan | 3 x BlackIce SR-1 480mm | NB eLoop Fans | Aquaero 5 XT | Dual D5 | Aqualis XT Res
https://linustechtips.com/topic/39034-sql-text-form-help/#findComment-514137
