which mobo do you have?
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/389852-cpu-fan/#findComment-5264047
Its runs as fast as possible under load by default. All modern (past 5 years) mobos have default fan profile which has less speed when its idle or low temps and ramps up when under load or higher temps.
E: Also mobo and cooler would help.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/389852-cpu-fan/#findComment-5268285
