Hello!
My PC has a black-white(-red) colorsheme, but my Razer Naga 2012 and my Logitech G110 (especially the Naga) don't fit in this colorsheme.
Therefore I'm asking you if changing the LED's is possible ans how I do it.
I hope you can help me.
Martzel
Mainboard: ASUS Maximus IV Extreme   Processor: Intel i7-2700K   RAM: 16GB GEiL DDR3-1333   Graphics Card: Sapphire Radeon R9 390 Nitro Tri-X
SSD: 500GB Samsung 840 Evo   HDD: 1TB WesternDigital   PSU: 850W Corsair RM850
https://linustechtips.com/topic/388585-modding-mice-and-keyboards/
Hello!
Martzel
Find similarly specced LEDs and remove and replace.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
http://www.overclock.net/t/1204061/razer-naga-mod<-- maybe this thread can help you a little
What you would need would be basic skills in soldering (and a soldering iron to do that),
some LEDs (and the fitting resistors, to get the right voltage in the circuit  please correct the bs I just wrote )
and all the tools you need to get that thing open.
I once had one of these, now I've got this.
Thank you! Does someone know where I find the exact values, so I can order some LED's?
It depends on the surface mount (SMD) LED's if they are SMD3258 or SMD5050 it will be fairly easy to get those exact ones from LED strips or replace them with diode LED's.
Note each color has difference specs:
http://www.wayjun.com/Datasheet/Led/3528%20SMD%20LED.pdf
http://www.wayjun.com/Datasheet/Led/5050%20SMD%20LED.pdf
