need help buying Dell e6430 . Pros and cons plz .
Solved by QueenDemetria,
hi
Hey I have two Latitude e6530's(soon to be one sadly), but the Latitudes from this series are great machines. They are well built and reliable, and the nice thing is that Dell's driver support for them is pretty good, so glitches are minimal.
Pros:
- Well built
- Reliable
- Upgradeable, easily
- Well balanced performance
- Surprisingly good speakers
- Ability to have a SSD and HDD at once(if you remove the DVD drive).
- The i5 runs cool and quiet, unless if you use it real hard
Cons:
- Compared to most laptops today, they are a bit thick and heavy(so like me in two years)
- Not the greatest battery life(I believe the 6 cell has good run times, just at the cost of having extra bulk).
- The paint on the frame wears off somewhat easily.
- Not the most modern
Latitudes are one of the few Laptops I recommend, I've had good experiences with them.
