Dual GPU cooling blocks?
Go to solution Solved by X_Rated_Box,
Are there any WC blocks for the 295x2 and the Titan Z??
EDIT:Woops I was just to lazy to google :D
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/387317-dual-gpu-cooling-blocks/
https://linustechtips.com/topic/387317-dual-gpu-cooling-blocks/#findComment-5227098
