i have the m65 and love it.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/386849-quick-help-on-what-mouse/#findComment-5220775
i play a lot of csgo and just want to know if I should get a steelseries sensei cosair m65 or asus rog gladius
Not the M65, it uses a laser sensor which you should avoid for CS:GO. If you must have the shape then the M45 is better as it has a better sensor.
What size hands do you have and what grip do you use?
Also, if you care my personal vote is for the ASUS.
https://linustechtips.com/topic/386849-quick-help-on-what-mouse/#findComment-5220792
whats wrong with the sensor?
https://linustechtips.com/topic/386849-quick-help-on-what-mouse/#findComment-5220806
https://docs.google.com/spreadsheets/d/1ZzbKDmFOqsP_ut2RdctD01OEbZzbXol6HLwqVkSmZcg/edit#gid=0
This is a list of mice that have sensors which do not exhibit any sort of acceleration or prediction, which helps greatly in CS:GO. I recommend the Razer Deathadder, Steelseries Rival, and Zowie FK1 as they the most popular mice for cs at the moment.
https://linustechtips.com/topic/386849-quick-help-on-what-mouse/#findComment-5221259
