Wireless USB Adapter TL-WN725N not working
Here is what I would try first. (Before you send it back)
1) Try a different USB port. - For example if it's plugged into the front try the motherboard directly.
2) Uninstall any software or drivers and then re-install them.
If the problem persists after this, try the USB device on a different computer (If you have a second one).
If all of the above steps fail, I would send it back or get in touch with your supplier about the device.
Featured Topics
Soapy1234 ·
Posted in Peripherals1 -
Shutset ·
Posted in Programs, Apps and Websites2 -
Codrut1001 ·
Posted in Troubleshooting0 -
4
Cypher-Jackson ·
Posted in CPUs, Motherboards, and Memory6 -
Yousef65 ·
Posted in Troubleshooting2 -
2
2
AtomAlchemist ·
Posted in Servers, NAS, and Home Lab6 -
5
