looks good, but one thing to ponder:
i'd relocate the tube from the top-right of GPU terminal block (drain?) to the
lower radiator on a 90° and a ball valve. the air present allows the pressure at
that point "compress" and make for uneven pressurization within the loop.
also drain port should be lowest point to allow a majority of coolant to be
removed without spillage.
https://linustechtips.com/topic/386136-project-red-0db/#findComment-5212482
I know, the problem is the bottom xspc block dont like the ek compression fitting. The threads on the bottom port is all no good except one. So i had to put the drain on the top block.
https://linustechtips.com/topic/386136-project-red-0db/#findComment-5213296
  • 3 weeks later...
  • 3 weeks later...
https://linustechtips.com/topic/386136-project-red-0db/#findComment-5649039
thanks but im in australia and its $50 for a 44 key controller, 5 meters of 5050 leds and power. not to to bad :P
Returning after 8 years dormant
https://linustechtips.com/topic/386136-project-red-0db/#findComment-5649591
