Will these work?
Hey guys,
I will be building my first PC and have chosen the components. I checked to see if they were all compatible and I found that they were, but It would be great if you guys could double-check  the parts for me, because this is my first build. It would be a lot of help if you guys could give me insight on what kind of performance I would get from this PC, as it will primarily be a gaming PC. The last question for you guys I have is if Windows 8.1 PRO is necessary for me (vs just 8.1) and what version should I buy if I am installing it by creating media (flashdrive). For example: DVD bundle, OEM version, just the activation key?
Thanks
Parts:
I left out the case, Optical Drive, and Ram because I bought an ATX case already and Optical Drive and 8gb DDR3 Ram is purchased too.
Thanks guys!
https://linustechtips.com/topic/385736-will-these-work/
why did you post this twice?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/385736-will-these-work/#findComment-5207469
Try using https://pcpartpicker.com/. It shows you if any parts are incompatible from the firmware standpoint to the physical standpoint.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/385736-will-these-work/#findComment-5207471
Hey guys,
Thanks
Parts:
Thanks guys!
DO NOT BUY THAT MOBO! It is incompatible with your CPU. LGA 1150 vs LGA 1155.
https://linustechtips.com/topic/385736-will-these-work/#findComment-5207478
