Wifi Network not sharing.
Solved by Matt420740,
I tried reconnecting them, the lights for the ethernet cables are flashing for both computers. I'll try to update the drivers.
Thats what I was going to recommend next. Make sure to find out the model and make of each motherboard, and go to the manufactures website to get the latest Network Adapter drivers. Windows will hardly ever update to the newer versions of those drivers via device manager, you have to manually download and install them.
