if you need a full priced phone then get the new phone form asus. otherwise get the droid turbo. my dad has it And HE LOVES IT. its a good buy
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/384955-need-replacement-phone/#findComment-5197176
looking for something that is rugged and will play music, and would be ok with like...youtube every now and then, but it needs to be able to take a beating.
https://linustechtips.com/topic/384955-need-replacement-phone/#findComment-5197323
