MySQL query print help
Go to solution Solved by mantylt,
@Hikaru12 follow your own topics.
I might be wrong, but you are selecting count(*) which is one result, integer, you don't need cycle for that.
$result = mysql_query("SELECT Count(*) FROM myanimes WHERE Status='To Watch'");$row = mysql_fetch_array($result);    echo $row[0];
$result = mysql_query("SELECT Count(*) FROM myanimes WHERE Status='To Watch'");	while($row = mysql_fetch_array($result))	{	 echo "$row[Status]";  	}
The above works fine in a SQL statement issued directly but when I try to print it it does not work claiming an "Undefined Index". Is it possibly because it's out of range?
Status is set as a VARCHAR field in the database. I've also tried mysql_fetch_row because it only returns back a single row but I get the same error.
If I try to print it directly it claims an array to string error which makes sense since PHP understands tables as associative arrays.
NOTE: Yes, I am aware of the SQL injection. This is a low stakes program that will be loaded on a Raspberry Pi and will get updated in the future.
https://linustechtips.com/topic/384088-mysql-query-print-help/
I am sorry for my english.
https://linustechtips.com/topic/384088-mysql-query-print-help/#findComment-5185676
