Dead PSU - Need replacement 1050W+
Solved by Guest,
Can I interest you in a 2000W SuperFlower Leadex Platinum ?
https://www.overclockers.co.uk/showproduct.php?prodid=CA-031-SF&groupid=701&catid=123&subcat=2057
Joking aside you can get the EVGA P2 1200W which is a very good psu if you want that much wattage.
https://uk.pcpartpicker.com/part/evga-power-supply-220p21200x1
It got a 10/10 review score from jonnyguru - http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=389
