Mushkin MKNSSDCR120GB-DX, 120GB SSD
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-493050
Samsung 840 Pro
Intel i5 4670K 3.4GHz | EVGA 780Ti Classified | ASUS Gryphon Z87 w/ Armor Kit | G.Skill Sniper 8GB @1866MHz
Samsung 840 Evo 500GB | Seagate Barracuda 3TB | Kingwin Lazer 850W Bronze PSU | Corsair 350D Window
Razer Blackwidow Ultimate BF3 Edition | Razer Naga Molten
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-493208
you can get a version with a full installation kit.
here is a link to one of Linus's vids that touches on it briefly
Within the kit you will also get an adapter allowing you to transfer data between PC's (using samsung magician software) if you have a use for that, I can also vouch for the 840 pro as a fast and super reliable drive.
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-496954
@ManNextDoor email samsung?
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-497437
http://www.samsung.com/us/support/email/product/
I would email about the 840 pro.
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-498534
I found this which is a live chat so it may be better. If not I would say 830 and then say since there is no option for 840...
http://www.samsung.com/us/support/live-chat.html
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-499781
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-500037
Any other suggestions?
Best option will seriously be the 840 pro and to just use this as a makeshift spacer
http://www.amazon.com/M-D-Building-Products-02055-Weatherstrip/dp/B000NUVISA
this way it will fit perfectly fine and you will get to enjoy the speed from the pro :P
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-501531
that would work or if you didn't like using that you could probably buy a 'proper' spacer from somewhere anyway
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-501734
Yeah except I tried to find one for 20 min to no avail, also lots of other people are experiencing the same issue with there being no 'official spacer' that you can buy for 2.5" drives although some people have made their own makeshifts using a sheet of 2.5mm acrylic sheets.
Regardless my opinion is basically that the need for a 9.5mm drive is completely unnecessary even when it comes to use in a laptop since SSD's are so resistant to shock.
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-501749
very true, i didn't try look for any but i thought there would be some available ?!!
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-501766
You would think so with the amount of people who would still like to mount SSD's in laptops and still use the spacers.. especially since most new SSD's are 7mm to comply with Ultrabook standards.
https://linustechtips.com/topic/38368-ssd-buying-help/#findComment-501778
