Help With New Build
Go to solution Solved by Colt_0pz,
Monmitor, OS, Keyboard and mouse? Um ismyour budget flexible? A decent 1080p 60hz IPS monitor is $150, a Keyboard and mouse combo with backlit from cooler master is $26, backlit is blue red or green depends what one you buy. Plus a OS from redditmor G2A is like $20. That's $200 and $600 for the PC. :)
you don't need an ips display unless you are working with colors. a tn will do
do you need a monitor or OS?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180061
What type of dollar?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180069
Yes,everything included.
[[PCPartPicker part list]http://pcpartpicker.com/p/Ydr9YJ) / [Price breakdown by merchant](http://pcpartpicker.com/p/Ydr9YJ/by_merchant/)(
Type|Item|Price
**CPU** | [intel Core i5-4460 3.2GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54460) | $176.98 @ NCIX US
**Motherboard** | [MSI Z97 PC MATE ATX LGA1150 Motherboard](http://pcpartpicker.com/part/msi-motherboard-z97pcmate) | $89.99 @ Newegg
**Memory** | [G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/gskill-memory-f312800cl8d8gbxm) | $60.89 @ OutletPC
**Storage** | [Crucial MX100 128GB 2.5" Solid State Drive](http://pcpartpicker.com/part/crucial-internal-hard-drive-ct128mx100ssd1) |-
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | $49.99 @ Amazon
**Video Card** | [EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card](http://pcpartpicker.com/part/evga-video-card-04gp43966kr) | $239.99 @ Amazon
**Case** | [NZXT S340 (Black/Blue) ATX Mid Tower Case](http://pcpartpicker.com/part/nzxt-case-cas340wbb1) | $68.99 @ NCIX US
**Power Supply** | [seaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply](http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm) | $79.99 @ Amazon
**Monitor** | [benQ GL2460HM 60Hz 24.0" Monitor](http://pcpartpicker.com/part/benq-monitor-gl2460hm) | $149.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | **Total** | **$916.81**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2015-06-09 16:21 EDT-0400 |
To get the OS, i would goto /r/microsoftsoftwareswap and get windows there for around $25
Edited by Colt_0pz
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180075
hmmm ok that will make things difficult. but i will try
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180102
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180113
http://pcpartpicker.com/p/mNgYYJ here you go. like 3 dollars over budget but oh well
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180128
I'm not really into that keyboard backlit thing.But,yes,again everything you said,included.
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180140
can you make do with a PS/2 keyboard? they are really inexpensive. not to be confused with cheap. cheap means something that's low cost and sucks while inexpensive is low cost but very good
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180146
can you spend 830? i managed to fit everything in except keyboard and mouse. you can turn off the backlight btw
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180147
It's backlit but like I said it's a nice quality keyboard and mouse combo for $26ish. Is you budget flexible at all or no?
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180154
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180165
i think this build is really good since you are asking for a monitor and OS http://pcpartpicker.com/p/mNgYYJ
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180177
you said the same thing twice. not literally
i felt like it kinda got ignored even though its pretty good so i posted it again :P
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180189
http://pcpartpicker.com/p/sYRfcf$800. Don't take anything less.
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180231
i was hoping,for a more powerfull cpu,since i am going to run autocad
Read my previous post but if you can expand your budget $100 you can get a 4690k and a z97 board to overclock
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180234
Thank you for your help!
http://pcpartpicker.com/p/7sVtyc Or you could get a Xeon, it won't be as good for gaming but would be better for rendering, auto ad ect ect...
https://linustechtips.com/topic/383671-help-with-new-build/#findComment-5180251
