I have a Haf 912,i5 4690k,CM 212x
I would want to know if i should attach case fans?
how would the cm jetflow perform?
does case fan help improve the temp?
TIA
at most 2-5c. are temps high in the first place? like higher than 70c, if so case fans would probably do some good. noise is the biggest reason to buy fans if temps are good. i honestly have never used the jet flow fans. for noise these fans are decent- noctuca, be quite, noise blockers, cougar pmw ones, phanteks and fractal.
https://linustechtips.com/topic/383350-case-fans/#findComment-5175852
