Haf 912 Compatible Cooling
Solved by JebKerman,
then should i just go for the case fans?
Well, 2 intakes and 1 outtake is a fine combination, you can't get much more out of having more fans. Living in a hot country will always limit overclocking potential, regardless of the cooler used.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
