So one night recently I bought a 420 rad, Swiftech H240x, and a EK block for my 290x. The plan was to hardline this all into a Corsair 750D with the 420 rad on top and the H240x in the front. I bought the fittings and bending kit last week, then after I ordered it I realized I don't know if it's doable with hardline on the H240x in the front how I planned considering where the fill port is on the H240x. So I'm coming here for some suggestions since this is my first full loop and I'm a bit confused now. I'm thinking I might be able to get a tube res to add in that can connect to the H240x, or can I do it without the tube res? Also I don't know where or how I'm going to add a drain to this loop.
Help is greatly appreciated since I'm stumped now. If I left out any info that might be needed let me know.
https://linustechtips.com/topic/381752-loop-route-help/
And always add the drain at the lowest point in the loop. Let gravity do the rest
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/381752-loop-route-help/#findComment-5156643
