So I have a plan, kinda, to make a new case because I just don't like my current case which is a Thermaltake S41 Urban.
It's a rather simple idea, the front, outer side and top will be made from 5mm thick acrylic. With room in the front for twin 200mm fans and the other fan stuff I will add as I can be bothered xD
One thing I am not sure about is that I will have to mount the keyboard on the left side of the case, So i have to decide on how to do that. My first idea was to just scuttle on old case from the local markets that would fix my MSI Z87-G45 board and then screw that onto the left side of the case, because I'm not sure about making my own holes for mounting the motherboard. Ideas?
Also thoughts on the overall idea for the case? And No I am not lighting this up, I personally hate LEDs at lease at this point.
https://linustechtips.com/topic/381273-clear-case/
You should make a square chassis, with everything made out of acrylic.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/381273-clear-case/#findComment-5150220
Like this ?
http://www.newegg.com/product/product.aspx?Item=N82E16811148001
P.S. Don't forget to follow your own topics so you are notified when people post replies.
:)xD9_9:D:PB|
https://linustechtips.com/topic/381273-clear-case/#findComment-5150253
Looks interesting, why go with the jigsaw interlock over say a hinge or pin?
depends on whether you want it completely clear, or to have bits of metal ie. hinges and pins in it
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
https://linustechtips.com/topic/381273-clear-case/#findComment-5179541
