Hey guys, I figured out that I want a drain on my loop. The place that makes the most sense to me is on the bottom of my second gpu (with a multi port wb). I would put a T fitting with a bitspower mini valve on one end and a compression fitting on the other. Would this cause any issues in my loop? Would the flow rate be affected much? Thanks in advance!
https://linustechtips.com/topic/381248-drainage-system-location/
As long as there is no liquid leaving the loop, there won't be any issues. In you case, the valve will be closed and the flow will be unaffected.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/381248-drainage-system-location/#findComment-5149915
Depending on the size/layout of your loops, so might you want to use more then 1 drain port.
My 3 rad system had a drain port at the reservoir, which worked fine, untill I found out that it emtyed less then half the loop. Turns out my tube routing made it impossible to drain the entire loop from the reservoir.
https://linustechtips.com/topic/381248-drainage-system-location/#findComment-5151774
