Hi I thinks this is afoot build all tips welcome I also need a name maybe red hydra idk thanks http://uk.pcpartpicker.com/p/2msGYJ
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
https://linustechtips.com/topic/380854-first-build/
What do you want it to do.
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
https://linustechtips.com/topic/380854-first-build/#findComment-5145566
I updated your build a little to give bit more performance :
http://uk.pcpartpicker.com/p/KD96gs
I also changed the Haswell-r to a normal Haswell to avoid needing a bios flash.
Recommend the CM Elite 430 as a case. better quality..
https://linustechtips.com/topic/380854-first-build/#findComment-5145814
I updated your build a little to give bit more performance :http://uk.pcpartpicker.com/p/KD96gs
How hard is it to do a bios flash
https://linustechtips.com/topic/380854-first-build/#findComment-5151962
For a few quid more, get this - http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
It's much better
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/380854-first-build/#findComment-5152023
