I apologize if the answer to this is blatantly obvious. I'm just looking to clear up some small confusion
I recently bought a new CPU and Motherboard so I'm getting ready to deactivate my windows 7 product key so I can reinstall it to work with the new hardware.
I watched this video here to see how to find and uninstall my windows 7 key
So, once I reinstall windows 7. in can enter that key that I previously deactivated, and it will work?
This is the very first time I've ever delt with having to deactivate a windows 7 product key, and I just want to make extra sure that I didn't skip any important steps and end up messing everything up
Thanks for your time!
https://linustechtips.com/topic/380708-re-using-a-deactivated-product-keyid/
No need to complicate it like that... When I changed my mobo+CPU, I didn't do a single thing... just switched the components, booted up, then a prompt appeared to re-activate via Microsoft hotline, 5minutes pass, done! :)
@ShaunOfNintendo - follow your topics :P
How do you deactivate a Microsoft Windows Product Key?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Really?
I've been told countless times that a fresh install of an OS needs to happen if you're changing your CPU and/or Motherboard
Does it make a difference if the two use different CPU chipsets? My current motherboard uses LGA1155
Really?
I changed from 1155 to 1150 and no issues regardless :)
There wasn't any conflicts between the drivers of the two motherboards?
I thought you would at least have to remove the old drivers
Oh, yeah, forgot about that :D of course you need to remove them :) But a fresh OS install is also good, but there is no need to de-activate the key ;)
Okay thanks
I'd rather not have to do a fresh install since there are some programs that I have on my SSD that I don't want to go through re-installing again
Would you happen to know if there's any program I can use that can help me locate those drives, or will I just have to manually remove them?
Okay thanks
After you change the mobo+CPU, boot up and try Driver Sweeper for example :)
