I had recently bought this Cod Aw edition Xbox one but when i try to connect it with a wired connection its not even picking up the wired connection at all so maybe i thought the wire was bad so i plugged my old xbox and the wire works great. why doesn't it work? can it be defective?
https://linustechtips.com/topic/380580-xbox-one-wired-problems/
potatoes can't connect to the internet silly boy
Nobody likes an asshole giving asshole responses to someone who wants real help.
Go into your settings and see if the wired connection even shows up, if it does do all the tests there and then try it again. If nothing else works, might have to bite the bullet and do a system reset. Go small to big in terms of severity of fix, might just be as simple as doing a hard rest (settings -> Power(?) -> restart I think, you'll know when you see it)
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5142435
Try to install the default driver for the xbox controller
http://support.xbox.com/en-US/xbox-on-other-devices/windows/xbox-controller-for-windows-setup#4f5c0f5746e44af88a346c6fde5fc727
Yes I know it says 360 but it should still work
And the rest of yall suck xD
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5142444
You come to the wrong neighborhood boy!
But seriously, although i think we should all have PC's, I'll help ya.
Go into your settings and check your connections, see if your wired connection shows up
@AStateOfTrance dude i own a pc but its nice owning a console as well.
@everyone else:p like when i connect the cable thru the back it doesn't even say its connected or anything it just tells me i need to connect a ethernet cable but i already have one there. could it be defective?
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5142800
Oh and btw i had already done a full system reset and nothing i think the xbox has a bad input :/
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5142811
If it works for your 360 then I don't see why it wouldn't work for your One.. :/
i had already own a xbox one i just bought the AW edition since it has a 1tb hard drive plus its limited edition i got it for $400 and well i tried the wire on my old Xbox and it worked then tried it on the AW and it didn't
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5143039
did you buy it second-hand?
https://linustechtips.com/topic/380580-xbox-one-wired-problems/#findComment-5143074
