Hey guys!So I rebuilt my 9 year old LGA775 PC 3 days ago,and the specs are a Pentium 4 524 HT(Cooled by a Xigmatek Apache III),4GB of RAM and a Asus Geforce 210.I tried to give a little kick to my system,and so I threw a slight overclock on the CPU,from 3.06 GHz to 3.15 GHz.The CPU went well,maxing out at 65 degrees,and I plan to overclock the graphics card too.I opened Afterburner and threw in some overclocks,stock speeds is 589MHz (Core clock) and 400 MHz memory clock.I managed to get it maxed out at 730MHz on the core and 500 on the memory,so when I stress tested it,it caps itself at 405Mhz core and 324MHz memory.What's going on???I need answers asap,and BTW im using the latest Nvidia drivers
https://linustechtips.com/topic/380155-gpu-clock-speed-will-not-go-up/
If I recall, nVidia severely hampered overclocking on some of the older cards. This might be once such case.
The GPU may be thermal throttling, do you remember the temps during the tests?, otherwise, it may have just deteriorated, was it covered in dust?
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
My only guess is that the card doesn't overclock well, becase of either nVidia, or simply time without use.
