I'm looking to make it easier to transport my Pentium G3258 build (specs in signature). I was wondering what the smallest case is that I could get to fit ATX as well as my 650Ti. I can get a new PSU if needed, but would prefer to stay with my current EVGA 500B. Currently, the computer sits in mid-tower case, Antec DF-35, but again, I'm looking to downsize.
Currently no price limit, but below $150 USD would be preferred.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/379886-smallest-atx-case/
HAF XB if you don't mind a cube case: http://www.coolermaster.com/case/lan-box/haf-xb/
290_2e49eef4ad79dffe904cdffe1a5038b9_136
Current Rig: i5 3570K @ 4.2 GHz, Corsair H100i, Asus Maximus V Gene, Asus GTX 970 Turbo, Patriot Viper Black Mamba 8 GB DDR-3 1600 (2x4GB), Sandisk 120 GB SSD + Seagate 500 GB HDD + WD Blue 1 TB HDD, XFX 750W Black Edition, Corsair 350D - https://ca.pcpartpicker.com/b/cbxrxr
https://linustechtips.com/topic/379886-smallest-atx-case/#findComment-5133025
I like it... Love it, rather. You very well might get the solution for the question, but you're also the first reply. Going to hold off for a bit and wait for some other recommendations :P Thank you though!
https://linustechtips.com/topic/379886-smallest-atx-case/#findComment-5133068
@gill2k do you know the difference between the HAF XB and the HAF XB EVO? They appear to be the same price, but different cases. I haven't had the chance do investigate any further. Likely going to do so tomorrow unless you know the answer.
https://linustechtips.com/topic/379886-smallest-atx-case/#findComment-5133563
HAF XB Evo is a re-release version that replaces the molex connector on the hotswap bays with a Sata power connector to address some dead drive issues, as well as some QOL changes. In other words, just a better version of the same case.
Also, If you can land a sale on it, http://www.newegg.com/Product/Product.aspx?Item=N82E16811139022
I've seen the all black version go for as low as $89.99, but I've heard it has gotten lower with rebates as well as the instant discount savings.
I just purchased the silver version myself not an hour ago, downsizing my NZXT Phantom, I'm getting too old to lift 60 lb cases*After everything is in it*
I was torn between the HAF XB EVO and the Air 540 for about a week, ultimately, I chose the Air 540 because of the window. >.>
Oh, by the way, if you get the HAF XB EVO, If you use an air cooler the size of a Hyper 212, ,you CAN NOT fit a normal 25mm thick 200mm fan, you would have to either place it outside of the case, or get yourself a low profile fan. That was the other deciding factor on the Air 540 for me.
https://linustechtips.com/topic/379886-smallest-atx-case/#findComment-5134024
