Hi, I want to connect my blue snowball microphone (uses a usb output) to my scarlett 2i2's xlr or 3 pin connector. This would really help me out. Also, if that is impossible then is there another audio interface that you recommend that supports either usb or 3.5mm inputs?
https://linustechtips.com/topic/379596-help-me-pls/
A USB microphone does not require an audio interface and cannot be used with one (because it has it's own ADC) and therefore there is no way to connect it to the Scarlett.
https://linustechtips.com/topic/379596-help-me-pls/#findComment-5129756
