Hey, peeps
apologies, if this is the wrong section, but...
I got a sick idea for a front panel H440 case mod (original idea by @modguru), but it will require two types of filter mesh - one black and one white (duh), and I need to know if the white is available somewhere.
It can be a cuttable version, like this one:
If anyone has some ideas, please post :) Thanks
https://linustechtips.com/topic/379301-white-filter-mesh/
you could make one yourself, I mean taking a White sheet of mesh/flyscreen and cutting it into shape
(http://www.amazon.co.uk/Insect-Screen-Material-White-continuous/dp/B003E6LP3I)
(http://www.flyscreenqueen.co.uk/flyscreen-material/white-flyscreen.html)
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/379301-white-filter-mesh/#findComment-5128106
This isnt actually a bad idea :) Thanks
https://linustechtips.com/topic/379301-white-filter-mesh/#findComment-5128751
:) no prob everything for you and your mod :D
https://linustechtips.com/topic/379301-white-filter-mesh/#findComment-5128937
yeah :) but that shouldnt be to hard also flymesh is waaay cheaper than any extra filter dedicated meshes
-voldemort-
https://linustechtips.com/topic/379301-white-filter-mesh/#findComment-5128968
-harry-
yes so hyped for this
https://linustechtips.com/topic/379301-white-filter-mesh/#findComment-5129416
