So I need more airflow in my case and there is one more spot for a fan at the bottom, problem is, there isn't very much room. I will move the hard drive up one or two slots, but most fans I have hit on that first cable on my psu. I was thinking that a fan like corsair's sp120 might miss it but I think there are probably better options, I was hoping for 60 cfm or better. Thanks for the help, it's much appreciated  :)
post-14337-0-21185600-1374387544_thumb.j
NZXT Tempest 210, 4770k @ 4.6ghz, Phanteks PH-TC14CS, 660ti DirectCUII @ 1180mhz, Asrock extreme 3, 8gb gskill sniper, ocz zt series 650w, wd blue 1tb, CM storm Quickfire w/ mx blues, Team scorpion X-Luca http://linustechtips.com/main/topic/42301-the-mean-green-machine/?p=550606
https://linustechtips.com/topic/37920-help-picking-fan/
Why don't you flip your PSU over do that the bulkier and larger cords are closer to the back of the case where you tuck them behind the side panel easier giving you more fan space and better airflow
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487488
yeah as Hazy said you should flip over the PSU so your 24 pin cable is out of the way. Right now its almost impossible to fit a fan there because it's going to hit the 24 pin.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487495
that will work, I never thought about that
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487497
What case do you have?
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487505
its a nzxt tempest 210
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487510
What is your current fan set up now?
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-487537
I have two 140mm fans in the top, one 120mm in the back, and two 120mm in the front
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-488331
Thats not a bad set up except that it's has negative pressure inside the case meaning that you will have to clean it out more often. But for the fan selection at the bottom I don't think that a fan will fit because it's going to be bumping up against your power supply.
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-489320
Ya, I flipped it today and tested it with a fan I had lying around, fits perfectly. As for the fan I was planning on putting in there, I was thinking about buying this gelid http://www.newegg.com/Product/Product.aspx?Item=N82E16835426025
 I was hoping for high cfm and decently quiet.
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-490308
Great that you can fit a fan at the bottom. I would suggest getting a fan that has high static pressure because since the fan is going to be against the floor and won't have that much of a clearance then it can push more air because there isn't that much room from the floor to the bottom of the case.
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-491466
100% agree on that, rated cfm doesn t mean much with such a restrictive fan position
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/37920-help-picking-fan/#findComment-492325
