It's easy to pick laptops, just move your hands near them, get a hold and move your hand up. Volla, you picked a laptop.
The lenovo Z40 looks good at this price point.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
Hey Sambo656
When choosing a computer, certain compromises has to be made (Unless you're spending +2000 $ on a machine), so list your specific preferences (Good/Bad screen, Screen Size and batterylife).
I will list my 2 top laptops for you, and if you list some criteria i will do my best to forfill them with links ;)
http://www.amazon.com/gp/product/B00KB3MXH4/?ie=UTF8&tag=datarecoverye-20&linkCode=ur2&camp=1789&creative=9325(This is one of the best price-to-perfomance laptops you can come across)
- (And if you hate the beats logo and color scheme, then this laptop is also excellent): http://www.amazon.com/Lenovo-Z50-70-Laptop-Computer-59436278/dp/B00O4RSPJI/ref=pd_cp_147_1?ie=UTF8&refRID=0PZMRAHSD7EFMGBKPTD2
Bear in mind that these laptops most likely are on sale but you should never buy anything list priced ;)
Hope this helped you in your search for your perfect machine <3
Hey Sambo656
WOW, thanks for all the info, that beats laptop is perfect for my budget.(looks really stupid though) but it seems to have good performance. that lenovo looks good as well, a bit pricy. what do you think about the integrated graphics version that drives the price down to 619? http://www.amazon.com/Lenovo-Z50-70-Laptop-Computer-59436278/dp/B00O4RSPJI/ref=pd_cp_147_1?ie=UTF8&refRID=0PZMRAHSD7EFMGBKPTD2
i just now did some digging and also found this: http://www.amazon.com/Lenovo-Z50-Laptop-Computer-Generation/dp/B00OJHHYOA/ref=as_li_ss_tl?ie=UTF8&qid=1432592425&sr=8-1&keywords=lenovo+laptop&linkCode=sl1&tag=fruitninjarev-20&linkId=ZDMSJCX66KFS264E
so far my only concern is about the gpu
Hey again! Sambo 656
I found this jewel on sale! :D
It has a 840m (Powerful enough to game even modern games on medium-to-low settings at +30 fps at a respectable resolution, like HD+ or HD-Ready)
- http://www.amazon.com/Acer-Aspire-V3-572G-76EM-15-6-Inch-Platinum/dp/B00R45U20W/ref=sr_1_1?s=pc&ie=UTF8&qid=1433277598&sr=1-1
The only consederation of this laptop is the disapointing 1 Tb HDD (5400-rpm), the ultimate thing would be to upgrade to a sshd in the futue (for like 50-75 bucks) Thereby improving the speed to a true pc-masterrace gaming experience.
It will be able to play standard steam games (CSS,CSGO,TF2 & G-Mod) at native 1920x1080p resolution at MAX settings without a sweat
Hoping you're one step closer to choosing a laptop for your needs <3
thanks for the find. the reviews dont seem to be too good though.
hello, i am trying to find a laptop that performs well. it will be used for school, internet browsing, maybe some light video editing, and light gaming (G-mod, CS-GO) portability is important. my budget is 600-700$ if that is at all possible. please help, thank you
Lenovo y40 would be a great option, and pretty much perfect for what you are doing
My Cheap But Good Rig: I7-3770s, Intel Motherboard (actually made by intel), 16gb DDR3, Nvidia Gtx 1070, 250gb Samsung 850 EVO SSD, 750gb HDD, Evga 500 BR power supply
Hey Sambo656
http://www.amazon.com/Lenovo-15-6-Inch-Laptop-80EC000TUS-Black/dp/B00K6ZIBGY/ref=sr_1_11?s=electronics&ie=UTF8&qid=1433342648&sr=1-11&keywords=Lenovo+a10
This is the best price to performance you can get anywhere
I would that the Lenovo above won't disapoint. But for the money he actually has, futureproofing for just a couple more years is worth the extra 150 $
It is just plain better at gaming than other pc's in the pricerange, but he could game better for the money he arlready has to spend  :D
