I have been pondering over cooling for quite a while now. I've gone from wanting a 212X to a R1 Ultimate to a H100i to a X61 to a X41 to a H80 GT to a H100i GTX... the list goes on for quite a while.
Would a cooler cheaper than a H100i or X61 like a 280L be better than them when some nice SP140s are put on there?
The H100i and H100i GTX have been dropped in price quite a bit recently, but their fans are loud as hell...Worth the noise?
For just some light overclocking, would something like a H80i GT be fine? Or, the Raijintek TRITON is only $120, would that be a viable option?
So, what is in your opinion the best solution for cooling? Would a lesser AIO with better fans be better than a more upmarket AIO? I will take all ideas into consideration.
NO CUSTOM LOOPS
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/378612-help-with-a-cooling-solution/
the default fans are actually better (at cooling) on the AIOs, faster and louder.
The Air coolers are almost always going to be better performance per dollar, and have no drastic point of failure.
I'd say the R1 Ultimate would be the best thing to get (if you have low profile ram AKA heatspeader barely goes above the PCB, R1 Universal if not), performs fantastically on my 4690K (keeps it under 45°C in GTA V only just hits 70 during stress-tests at my OC)
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Getting positive vibes for the R1! What about corsair vengeance pro? It'sl low but I'm not sure if it's low enough.
Also, 45 degrees? What's your overclock?
 My Buyer’s Guide!
Build:
In sig, but:
Ratios: 47,47,46,46
Voltage: 1.276V
In sig, but:
Ratios: 47,47,46,46
Voltage: 1.276V
Well, in that case for much less than any AIO and those kind of temps I'll take it!
R1 Ultimate it is!
What about my RAM Vengeance Pro? I can switch to Fury if necessary. I think I'll do it anyway...
 My Buyer’s Guide!
Build:
R1 Ultimate it is!
If it's the ones that look like THIS then, no it won't fit
Ok, I'll just get some Kingston Fury White Series then. It's ok, they're cheaper and come at a high clock speed. So it's all good :D
 My Buyer’s Guide!
Build:
