Hey Guys,
My Logitech G110 Keyboard has Makro-Keys (G1-G12) with 3 different Profils (M1-M3) so a total of 36 programmable Makro Keys.
You can add per profile even one Lua-Script. Because I dont know anything about Lua and dont have time to learn it, I want to ask you guys if you could help me programming this script:
I Want an simple Counter. Everytime I press G10, for example, 1 Should be added to x.
So if I pressed G10 20 times: x= 20
After some pressing and counting I want the number to be written down with an other Key (G11 for example).
My English is not the best so I hoped I explaid it right.
I would be REALY thankfull for any kind of help. :) Feel free to ask
PS: Is this even possible? O.o
https://linustechtips.com/topic/378141-searching-for-g110-script-lua-counter/
this is a lot simpler than the voodooo my G110 is running (my script regularly locks up the logitech software)
i could work on a small script that'd do what you want, but i'm probably gonna make some huge missers as i'm sick as a dog today.
No stress pls :)
If you have time and the knowledge and feel better it would be realy realy awesome from you.
I would be so thankful you would not believe it :D
Thank you for your help :)
No stress pls :)
i feel better today, so i'll have a go at it:
-insert restarting logitech gaming software here-
counter=0function _OnEvent(event, arg, family)    if (event == "G_PRESSED" and arg == 10) then        counter++    end    if (event == "G_PRESSED" and arg == 11) then        -- typing numbers here, i'm gonna work on how that works.    end    if (event == "G_PRESSED" and arg == 12) then        counter = 0    end
https://forums.logitech.com/t5/Logitech-G-Keyboards/Chatting-Writing-Function-for-LUA-script/td-p/562806
using the write function of this you "should" be able to write(counter) in the second if statement.
