Hi all, i have the i5 3550 CPU, i set the multiplier at x41 (doesnt go higher) and the bus to 105, it goes to 4.3Ghz.
I dont have any problem at all, the only problem is that some times when i start the PC, the OC fail.
Need some help please!
Thanks!!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/377867-cpu-i53550-fail-oc-help-please/
Thanks!!!
It's not a K CPU, so any OC on it is better than nothing. No OC'ing is promised since it isnt a K.
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
105 for the bus is really pushing it. try 103.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
well it is stable at 105, it can run for days without any problem, really!! And running new CPU intensive games for hours!!
But out of nowhere, like after one week, 10 days, it fail at start......
Any advice for my issue??
