Hey guys!
Did you ever noticed that on your mouse? How can I fix this?
Best regards!
http://www.overclockers.com/mouse-clicking-troubles-diy-repair/
Link isnt for your mouse, but click issues,....You may very well have to take it apart and such... to remove that vibration.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/377394-mouse-click-noise/#findComment-5101187
So is it an actual issue of the mouse? I mean..it happens to all of them?
Alsi..I want to clarify this..I do not experience doubleclicking...it's just the sound that is really weird and drives me insane. I do not even have this mouse for a month.
Of course it doesn't happen to all of them.  Its most likely a QC issue.  Maybe the mouse wan't assembled with proper clearances, etc.
If the mouse is less than a month old, and you haven't split anything on it or dropped it, then this shouldn't be happening.  I'd try to RMA the mouse.
https://linustechtips.com/topic/377394-mouse-click-noise/#findComment-5101508
