I've been hearing many bad things about premixed coolant, but I've been using EK clear coolant for a while now and haven't had any issues. Since I will be redoing my loop, I was wondering what coolant I should use. I have UV blue tubing so I don't need colored liquid. I heard that distilled water is the best, but is this the distilled water that people drink or is it something different? I would rather go with normal coolant like the EK or maybe something else if possible
Have you tried turning it off and on again?
https://linustechtips.com/topic/37705-water-cooling-coolant/
Ya just normal distilled water. Or i heard (I dont know if it is recommended) But you can just boil water and let it cool and its the same thing. but again, i dont know if its recommended but thats what ive heard.
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484311
If you boiled water and let it cool, that's going to have even more contamination.
Distillation is the process of turning water into steam and then condensing it. Not just boiling it.
To the OP.
EK and XSPC coolants are the most problem free coolants out there. Just keep using them. :)
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484324
To the OP.
Thanks for the confirmation, I was wondering why everyone hates coolants from big brands :P Is it just the dyes that are bad?
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484336
As i said, Thats just what i heard :p
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484337
As i said, Thats just what i heard :P
From who?
What big brands? EK and XSPC are big brands. :o
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484347
From who?
I think it was like life hacker or something, I read it a while ago.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484354
distilled water + silver coil is the best solution if you don't care about colours and cheap.
You still need a corrosion inhibitor. In countries where Coolant costs the same as distilled water coolant is the cheaper option and works just as well.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484620
That's why I said silver coil, you can get them for £5 and last a lifetime. There is no need to buy it from special watercooling shop, you can buy normal distilled/deionised water it from anywhere are works fine.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484849
A silver is anti-microbial (a biocide), A corrosion inhibitor is there to stop corrosion. Different job.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484867
My error but why would it be needed if he isn't mixing metals?
Radiators typically have some aluminum/copper/brass in them, fittings can be a different metal, the inside of the pump can be a different metal. You're either going to be very limited in your choice of components or going to have to use a corrosion inhibitor.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484911
Not really, pretty much all watercooling hardware has moved away from using aluminum apart from a few radiators. You don't really need to worry about fittings normally plated brass. No need to use the exact same metal through out your whole loop or be picky about which parts you are using most companies have caught on now. Honestly watercooling has come a long way.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-484954
You can opt to go without it if you want but not spending $5 on a corrosion inhibitor in a >$300 loop is just asking for trouble.
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-485039
So if I use EK coolant I don't have to add anything to it? such as anti corrosion fluids
https://linustechtips.com/topic/37705-water-cooling-coolant/#findComment-486813
