I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/376823-difference-between-these-gtx-980s/
One is the G1 Windforce, one is the Windforce. It's literally just a different shroud and maybe a slightly different heatsink.
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
The shroud is different - the Windforce logo on the G1 lights up, while the normal Windforce card just has a shiny logo. The coolers themselves are exactly the same, and I believe the G1 is clocked higher than the normal Windforce edition. The G1 also has a binned chip, which could allow for greater overclocking.
Edited by Godlygamer23
This is the same card as the G1 right but cheaper?
https://www.overclockers.co.uk/showproduct.php?prodid=GX-148-GI
Yes.
The boards are the same. You can just flash the g1 bios to the wf3. (Google search, there is a good thread comparing them)
I heard that the binning is the same but I cant be sure... my g1 hits 1.5ghz. Not the highest but its still good.
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
