If my monitor is set to 120Hz in the nvidia control panel but in game it is set to 60Hz will the game override the nvidia control panel? And if I'm playing at 60Hz, is there a difference if I have Vsync enabled or not if I am playing at under 60fps? - Because I understand that adaptive Vsync disables Vsync when fps drop below 60Hz (my refresh rate) but why? What happens if you have Vsync enabled and you go under 60fps?
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/375998-how-does-vsync-work/
V sync Makes the FPS lock at a maximum of your monitors refresh rate so for example if you get a 60 Hz monitor and turn on v sync you will get 60fps max or if it goes bellow 60 it will drop itself to 30. it prevents artifact and tearing etc
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5084694
How come with Vsync enabled my fps goes down to as low as 40 but never 30..
Also what is the point of having refresh rates like 59Hz and 119Hz? What does this do?
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5084722
its just where the software stabilizes you FPS and 59 HZ is no real difference to 60 IMO as is 119 to 120
1
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5084738
snip
can your system even achieve 120 fps?
if it cant ,it should lock it to 60 i belive (like if you cant get 60 it goes to 30,correct me if im wrong)
its not actually 60fps, its more about 59.9*something*
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5084880
Syncs your frames to avoid screen tearing. Also avoids stuttering in some cases.
CPU:FX 8350 4.4 ghz (Upgrading to a 6700k!).Motherboard: Asus M5A99FX PRO R 2.0 (Upgrading to a Z170 Pro4!).GPU: Sapphire R9 290 (Arctic Cooler).RAM: 8GB Corsair XMS3 (Upgrading to 16gb ddr4 2400mhz!) PSU: Cooler Master B700. HDD: 120gb Hyper X Fury SSD, 500gb 5400rpm Caviar Blue Cooling: Hyper 212 (Switiching out with a Be Quiet! Pure Rock Slim for new build) 2x stock case fans.
Future Upgrades: h100i cooler, corsair sp120 fans, 1080p monitor, AMD->Intel CPU Switch
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5086481
On a 120hz display it goes 120-60-45-40-30,which makes me wonder why consoles never pushed for 120 TV's as it gives you 40 and 45 fps vsync that 60 lacks, which would make the experience much smoother
Intel i5-3570K/ Gigabyte GTX 1080/ Asus PA248Q/ Sony MDR-7506/MSI Z77A-G45/ NHD-14/Samsung 840 EVO 256GB+ Seagate Barracuda 3TB/ 16GB HyperX Blue 1600MHZ/  750w PSU/ Corsiar Carbide 500R
https://linustechtips.com/topic/375998-how-does-vsync-work/#findComment-5088414
