i need some help for my first build and suggestions on a few things i should get?
1.) i want to play at full 1080p 60 fps, but i do not know what video card i should get.
2.) ima build a mini-ITX rig with the thermaltake core v1 case but i want to replace the 200mm fan in the front for good efficient cooling and add 2 extra 80mm fans... but is it all worth it ??
3.) is a aftermarket CPU cooler worth buying ?cuz i heard the stock cooler for intel CPUs suck
heres my pcpartpicker list:
http://pcpartpicker.com/p/ZkrpLk
https://linustechtips.com/topic/375850-need-help-with-build/
What PSU will you be using?
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/375850-need-help-with-build/#findComment-5084056
