Hey all,
I got a question for you I am going to be cloning a few hundred SSD's over the next year as a contractor. Do you all know of a good solution to help with the cloning process maybe something that allows me to connect multiple SSD's and maybe some mSata SSD's as well to quickly clone the drives?
The other question I had was if I have Windows installed on these drives how will I handle the license numbers. All the drives of the same type will be inside the same machines so I am not worried about drivers and such but I imagine Windows installs would be a big issue? Any Advice?
https://linustechtips.com/topic/375410-cloning-solution-for-ssds/
I recently bought a Samsung 850 Evo and used Samsung clonning tool that worked great on cloning my OS drive and it was fast. Although Samsung tool only works with Samsung SSDs, it will only allow to clone from any SSD into a Samsung SSD.
I cant say the same from WD tool (Acronis True Image WD Edition) that screwed my Server OS drive completely by messing the partitions and boot.
I dont know any other tool, I would like to know as well, so I dont screw my server OS drive next time lol.
Really like the Paragon products, have used them a few times.
Paragon Deployment Manager can be used to deploy a standard image to multiple disks.
For cloning though they also have a software callled Drive Copy which ive always had success with. They also have a business supported product
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
