Alright I'm planning to build a system for my sister. She needs a computer to run her TV in the living room. She uses Netflix, hulu, and whatever else instead of paying for cable tv. For the past few years I've been on her about letting me build her a computer instead of using an old laptop. Well she finally gave me my chance but I've been away from hardware for a couple of years now so I thought I'd ask you guys for some advice.
This computer will basically just run chrome/firefox and play movies at 1080p. Maybe some light gaming, but top end graphics aren't necessary. Her budget is $700USD but a case won't be necessary because I talked her into letting me mount everything flat on a piece of acrylic. The budget is for the hardware only, I'll foot the bill for the acrylic and specialty mounting stuff and OS. I'd be willing to chip in a little for hardware as well if it would be large gains in performance. I would like for it to have an SSD for the OS. She already has a couple of external hard drives that I'm planning to take apart and mount to the acrylic and given that it's gonna be mounted with no real case, modular power supply is a must.
Another thing to consider is that I'm an Intel and Nvidia fanboy so...yeah Intel and Nvidia please.
What I've come up with so far:
CPU: Intel Core I5 4690K 3.5GHz Processor
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9174257&CatId=11497
Mobo: MSI Z97-GAMING 3 ATX Motherboard
Memory: Kingston HyperX Fury Red 8GB 1866MHz DDR3
Power Supply: ThermalTake TR2 Powersupply
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9636971&CatId=1079
Video Card: MSI GeForce GTX 750
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9117006&CatId=7387
SSD: OCZ Vector 180 Series 120GB Solid State Drive
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9658896&CatId=5300
That's all for now, thanks for any help!
https://linustechtips.com/topic/374713-700-wall-mounted-machine/
It is a bit overkill for just watching things/browsing?!
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/374713-700-wall-mounted-machine/#findComment-5068182
Don't be a fanboy. She just needs a media center. Just get the cheapest parts you can, that will still do the job, and install the Kodi Media Center on it. The build you described above seems like it will work just fine....so I don't see where the problem is. If you're software savvy, you can link Kodi up with all sorts of streaming services, and even use your phone as the remote for it. I'm sure there are posts somewhere describing how to do this, if you're not familiar with Kodi.
Screenaninator: Sapphire Radeon R9 390 Nitro
Procrastinator: AMD FX-8300
Stickaminator: 16GB Crucial Vengance DDR3
Powermathingy: Corsair RM850i
attachamajiggy: Asus M5A97 R2.0 f
Remembrerthing: 240 GB Crucial SSD, 2TB Toshiba HDD
https://linustechtips.com/topic/374713-700-wall-mounted-machine/#findComment-5068195
I want it to be pretty future proof. She has 3 kids and they might catch an interest in gaming some day. Oh and I need to mention that she wants a red and black theme.
I see what you mean. Urm.. if you are willing to spend the money on that.. then it would be good.
On top of the 4690k you could get an MSI Gaming 3 - they have a red and black colour scheme, and for the RAM the only type I really know of Corsair Vengance Red 4GB then... urmm... yeah
https://linustechtips.com/topic/374713-700-wall-mounted-machine/#findComment-5068267
