Hello, I'm looking for some In-ears for running since my last pair got water damage while doing the dishes. I want decent sound (not that important tbh) and what I'm looking for the most is that they have to stay in my ears while I'm running. I'm looking at "JBL reflect A" and they seem decent.
Any suggestions?
https://linustechtips.com/topic/374672-in-ears-for-running/
Any suggestions?
if you can afford it or it suits your tastes
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/374672-in-ears-for-running/#findComment-5067770
I'd probably buy them if they weren't so expensive. A bit out of my range sadly.
i'm just waiting for a good excuse to buy a pair of jaybird bluebuds X
Yeah... Se above :)
https://linustechtips.com/topic/374672-in-ears-for-running/#findComment-5067784
Budget is very helpful for people to make suggestions.
Also, Wrap the wire from any earbud / iem around your ear to help keep them in place and also reduce micro-phonics.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/374672-in-ears-for-running/#findComment-5067858
