The XFX unit is better in terms of efficiency and likely reliability, but the EVGA unit is still solid.
https://linustechtips.com/topic/374415-which-power-supply/#findComment-5064321
so is the extra $50 worth it? How much will i be saving on the energy bill with the xfx over the evga?
barely nothing.
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/374415-which-power-supply/#findComment-5064400
The first link doesn't work?
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/374415-which-power-supply/#findComment-5064451
Ah, that's better
Agreed, stick with the B2. It is made by SuperFlower based on the Golden Green, and is a very solid unit.
https://linustechtips.com/topic/374415-which-power-supply/#findComment-5064471
No, the B2 only lacks efficiency, which as stated above won't be noticeable. Performance wise outside of efficiency it's up there with the XTR
"Rawr XD"
https://linustechtips.com/topic/374415-which-power-supply/#findComment-5064781
