Hey guys so I will be getting my parts soon but this is my first time I am assembling a PC. I have watched many youtube videos including Linus, JayZ, Austin Evans etc. So i need to ask this... What can go wrong here? I think i got it but still, its a matter of a $1000.... Also i have no idea how to plug those front panel connectors, as i can see different motherboards have it in different location so will it be written below the header or I have to refer to the manual... Also how can i differentiate between fan headers and audio headers and also how many fans can i connect to my motherboard?
https://linustechtips.com/topic/374179-first-build-questions/
It all depends on which motherboard you buy
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/374179-first-build-questions/#findComment-5061320
