http://www.ebay.co.uk/itm/191025096255?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
my friends looking to get her first gaming rig she showed me this I think its low-med on game settings what do you  think
Build one yourself and dont build in the $300 range. It won't be good. Just save up for like $750 to get a better rig that might be able to triple the gameplay of your $300 build.
https://linustechtips.com/topic/373965-pre-built-system/#findComment-5058648
No. Just no. That thing is way too cheap. It only has an A8, upgrading that thing will be a bitch.
Follow the topics you create using the "Follow" button in the top right corner!
One day I will have my GTX 970. One day. PC specs are at my profile.
Not sure how to check what part works with what? Check out my compatibility guide!
https://linustechtips.com/topic/373965-pre-built-system/#findComment-5058652
what you think of this build http://uk.pcpartpicker.com/p/fDqR99
This PSU is cheaper and better quality - http://uk.pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/373965-pre-built-system/#findComment-5064560
