Radiator Help?
Solved by airdeano,
you can use that port, but it will diminish the cooling capacity or the radiator.
will turn a dual pass radiator to a single pass (less thermal transfer). this
would be a not recommended option. that port is usually used as a drain port
or a bleed port.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
4
play_circle_filled
Latest From ShortCircuit:
