For my new rig, wich ssd should I choose?
Samsung 840 (non pro) 120gb
OCZ Agility 3 120gb
Kingston SSDNow V300 120gb
They all cost the same and I will be putting my OS (WIndows 7) ,some games and some programs.
cpu:I7 4770k @ 4.3   gpu: 3.5 gb ( ͡° ͜ʖ ͡°) GTX 970 @ 1530MHZ   Ram: 16Gb
https://linustechtips.com/topic/37367-help-me-choose-a-ssd/
OCZ Agility 3 120gb
Heya,
They are all good drives, personally. I would say, the Samsung 840. As it is a great perform, and I know that their SSDs use the top grade nand flash for their SSDs. Also, their customer service is reliable, if any problems occur  (god forbid).
Elven
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/37367-help-me-choose-a-ssd/#findComment-480381
Get the 840 Pro. Its worth the extra money.
Most of the time, not really. The difference in speed is negligible and the average user rarely writes to an ssd. Both the 840 Pro and non pro will last quite a long time.
Get the Samsung 840 (non pro) if it isn't much more expensive than the V300. Otherwise, get the V300.
https://linustechtips.com/topic/37367-help-me-choose-a-ssd/#findComment-480409
