Hey! My phone wont connect to my gopro's wifi hotspot!
PHONE:                             Nexus 5 UNLOCKED
ROM:                                 CM 12,1
KERNEL:                           ELEMENTAL X
ROOT ACCSES:               YES
XPOSED FRAMEWORK:  YES
BOOTLOADER:                UNLOCKED
CAMERA:                         GOPRO HERO 3 WHITE
OS VERSION:                  3.0.0
https://linustechtips.com/topic/373631-help-wont-connect/
Is your phone not finding the GoPro, or is it giving you an error?
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/373631-help-wont-connect/#findComment-5054081
im going into the settnings and to wifi. Im writing in the password and then it just says finding ip and the after 1 min it stops and tries again
it works on other phones, it worked on my phone before!
https://linustechtips.com/topic/373631-help-wont-connect/#findComment-5054109
