9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
do they make one for a 970 ?
http://forums.evga.com/Any-plans-for-a-HYBRID-Water-Cooler-All-in-One-for-the-GTX-970-m2314908.aspx
 referencing this thread itll fit a reference PCB 970, so it wont fit the strix you have.
and a car thread !
You could try an NZXT Kraken G10 in combination with any old all-in-one cooler. It doesn't specifically mention it'll fit on a STRIX, but unlike that EVGA thing, it's not very fussy about the card you have. All you need is for the screw holes around the GPU itself to be in the same place as they are on a reference card, and you're good to go.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
Ya I was looking at the g10 bracket. It would cost me about 150$ for the bracket and a H55 aio to go on it.
and a car thread !
You could always ghetto mount a water block with zip ties but memory modules and vram might get toasty without heatsinks or fans blowing at them.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
either way my vrms are on the oposite side of the fan on the g10 so I have to either go buy a pcie fan bracket or ghetto rig a fan holder out of steel wire which is probably what I'll do
and a car thread !
