I am currently building a new computer so I'll get right to it.
My budget is around 450$. I need everything except a case, monitor, and peripherals.
I mainly play video games that aren't too graphic intensive like WoW, LoL, Dota 2, Skyrim, and Call of Duty. I also like to stream a lot of movies and videos and listen to music.
I will be using 2 monitors. 1 is at 24 inches and the other is a 32 inch HDTV. I will be playing games on the monitor and watching videos and surfing the internet and playing music on the TV.
I am building this because my current build is like 5 years old and it's starting to lag when I want to do what I want to do.
https://linustechtips.com/topic/3735-need-advice-for-new-build/
$450 really won't get you anything decent, certainly nothing good enough to play the games you mentioned. My personal advice would be to wait and save a little more, say to around $600, then that gives us something to work with. $450 is just too small a budget to spend on a decent gaming experience. Is there anything you can salvage from your old PC, like your RAM?
https://linustechtips.com/topic/3735-need-advice-for-new-build/#findComment-46295
Will you also need an OS? Also, where you are located?
As said $450 is a low budget, though considering the games you listed aren't to demanding you might still be able to get a reasonably good system, depending on the two questions I asked earlier.
https://linustechtips.com/topic/3735-need-advice-for-new-build/#findComment-46310
